Unfortunately, it a forever. You see, the one [output] transmission shaft is constantly turning with the engine. The other [output] shaft is connect to the rear wheel via chain. The clunk is when a sliding gear enters a spinning gear as it enters 1st gear.
For the clutch workings, the big clutch outer runs with the engine, the clutch inner spins with the engine [when in N], but when you pull the clutch in, the inner is still spinning; but once you step on 1st, the clunk, then the clutch inner stops spinning.
Does not matter new, well broken in, or a high miler, it's the spinning, noisy mechanics of the bike and that gear separation method. You won't find any posts about 1st gear replacements; so there really is no worry about.
For the clunk; I start in 1st, then slowly take off and let the bike pull me at idle to warm up. No clunk. 20k or so miles, if the traffic light is short, I hold the lever in and am always in 1st if it calls for a stop. No clunk. If I think I'm making heat, clutch in, not transfer of plate to plate for heat dissipation, I still catch N as if new.
Take it for what it worth... propane torched a new steel clutch plate, discolored blue and all, put it on a surface plate and notice no warp. So I figured if that plate takes the kind of heat, then a steel plate will never see kind of heat with my long holds, doubt it will turn color with the oil feed it gets anyway.
